HightechHillbilly
Industrial
Howdy,
I am really at a loss as to how to GD&T a hex bar. In my research, I've found that it's classified as an "Irregular Feature of Size" and that most ppl tend to favor a profile tolerance.
Attached is what I've started, but I've hit a roadblock because I'm not even sure if I'm on the right track.
The functionality of the bar is that it also has 2 "dimples" on opposing flats, which act as friction retention in a press fit application when pressed into a blind hex hole. The surface that I have tentatively labeled Datum "A" will contact the surface at the end of the blind hex hole. Obviously, the shape of the hex itself will keep it from rotating, and the "dimples" will deform when the hex bar is pressed in, causing a tight friction press fit such that it cannot slide out of the hole.
So, not only is my issue in GD&T'ing the hex bar itself, but also in relating the 2 dimples - I'm not sure if what I'm calling Datum "A" is correct, and/or if I need any other datums, and how to relate everything.
Any assistance will be greatly appreciated.
Thanks,
Rob
Thanks,
Rob
