gladiatorxx
Industrial
We are in the process of having removed the right side and back wall of an existing garage. The material is clay silt. This garage is set back into the land and the area is tiered. Thus the right side back fill would come up about 4ft against the right side garage wall at finish grade and the back side back fill would be about 6 ft at finish grade. We intend to use 3/4" stone against the new walls. It is the intent to use 12" block, filled with concrete and #4 rebar every 24" inches. Wall that was removed was 12" hollow, and had a 6 - 8" concrete wall poured against it fron the bottom of the footing to finish grade of the back fill.
Thoughts on what we now propose??
I can privide pictures if this will help
