functional gage
rupeshpahwa
Automotive
Mar 17, 2010
9
Thanks pmarc & drawoh,you both are very much right, but i have my drawing in that shape so i want to have Gage for that,without having any engineering change,can any body suggest ,how it will look like.
rupeshpahwa,
Ctopher is right. You should have continued the previous thread.
If you want to gauge this thing, then you really should use a profile tolerance on the hex. This will give you a well defined MMC state that you can test with a hexagonal, female GO gauge. Your NOGO gauge will be a fork, .3129" wide that must not fit over any of the three flats.
Your drawing controls width and angle separately. You can make a GO gauge fork to test each flat separately.
I figure that based on your positional tolerance of .010", and your across flats dimension of .315", you have a total angular tolerance of 3.6°. You should be able to figure out how to interpret a 120° comparator gauge. Accounting for the MMC state requires you to measure across flats with micrometer.
A well prepared drawing will save you all sorts of inspection time.
JHG
Drawoh,
Thanks a lot for your reply, I have one idea in my mind,i donot know i am right in this case , i have to hold on datum feature b to inspect the width. so i can have a mmc cylinder & two flats to inspect the width.
 http://files.engineering.com/getfile.aspx?folder=101ad1fa-eb2e-4d40-8b0c-975c2488dd6e&file=hex_gage.jpg
rupeshpahwa,
Your inspection gauge, as shown, will not work. You have a larger diameter between your reference diameter and your flats gauge. The piece that measures across your flats may have to be attached separately through dowel pins.
JHG
I am thinking to make the .38 at mmc & check the accross flats .315 with respect to that.
thanks
rupesh
