Jatfuentes
I am doing an estimate of the weight of an Industrial Structure, with cranes in all spans.
As usual I modeled the tranverse frames as moment frames, and the longitudinal frames as braced frames, with the end of connections hinged.
The dimensions of the building are approximately 540 Ft width, 1000ft lengtht, and 66 ft height to the eave. The Isometric of the building is in attach.
My question is about the influence of the hinges in the period/frequency of the structure response.When I considered everything continuous, including angles of the Truss, I got T=3.29 sec, but if I considered the structural normal. ( rigid in the transverse direction) , braced with hinges in the longitudianl direction and also the diagonals of the trusses hinged, I got T =30 sec. !!
I am using RISA 3D. Obviously do not exist perfect hinges in a truss, the value of the restriction is between fixed and hinged.
Some one can give me an idea?. there is any paper talking about this issue?
I will thanks your comments.
jatfuentes
jatfuentes
