Hello all,
This is a question about using springs to model a soil foundation, in a structural design software. The software uses "kN/mm" as an input value for the spring supports.
I would like to know if anyone here, either by experience or with a reference, can guide me to find some typical values to use as an input for the software? I have a doubtful source with values in "MPa/m" (which could be converted to kN/mm by using the tributary area of the support) but I'd rather use a more reliable source.
(I say the source is doubtful because it only gives me a range, i.e. "between 13.5 MPa/m for weak support, to over 270 MPa/m for strong support").
