I am looking to install a separator vessel (cylinder vessel on it's side) and it weighs roughly 1,200 lbs, and will basically be supported by by 6" wide flange on either end.
I am trying to figure out what the best (economics taken into account) base would be for it. The 3 options would be steel piles, cement slab, or compacted gravel (with concrete patio slabs for extra base). Obviously for support the best option is piles, but what do I need to take into account when deciding to construct a cement slab (could be expensive?) or just use compacted gravel? I assume when I talk to the contractor I can get them to compact to a certain pressure rating? Am I right, when I assume you can usually use gravel up to a certain pressure rating and then you have to go to a cement pad?
The second part to my question has to do with rebar. When is it needed? If I was to pour a concrete slab for this vessel how do I determine how thick I need it and if it needs rebar? I assume these are all questions I can ask the contractor, but I'd like to get some info first.
Thanks!
Thanks!
