A foundation will be designed for a large new vertical turbine pump with a suction can. Given the size of the proposed pump, I suspect the foundation will take the form of a thick walled concrete cylinder approximately 6ft in diameter x 15ft deep in the ground. Since this is near the Gulf Coast, I believe the Civil Engineers' default will be to stick a bunch of piling under it.
I can't help but feel that a foundation this deep will be somewhat self-supporting, if looked at in the right way, so that installing piles at the bottom of a pit can be avoided.
Any suggestions for alternative type design methods to look at? I do not speak civil/geotechnical, so may not come up with the magic words to sway them from a default design path on my own. Not sure if this could be looked at as a drilled pier or other, or there is something specific that should be asked for in the geotechnical study (typically the soil studies will focus on the ground bearing for spread footers and allowable loads for depth x dia of piling).
If there is no feasible way around piling, that is OK too; thought I would check.
