Jdmmech:
In the orientation you show the tab, it will not have a bending moment under ideal conditions, as Irstuff suggests, the loads will be in the same plane as the tab. But, a thin tab at that angular velocity might likely act as a thin, unstable airfoil, and vibrate off the cylinder in short order. Also, that tab will cause the entire cylinder to be out of balance if that can be a problem.
