310toumad
- May 12, 2016
- 63
How would I go about solving for the moment(s) at the base where this structure is fixed? From looking at examples of frames, a few assumptions are typically made to reduce the indeterminacy of the problem. For this case, can I assume the reactions acting opposite to the applied 1430 forces are also 1430? The problem I run into with this is that, if I assume that the horizontal member has a point of inflection at the midway point, how do I resolve the internal forces when "cutting it in half" and doing an force equilibrium analysis to find the moment at the base? If I already have assumed the applied force and the reaction are equal, then any internal force in the beam would have to be zero in a force balance, in which case your moment is just 1430*25.5. I don't think that is correct, the horizontal member connecting the two should 'stiffen' and lessen the bending moment logically. What am I assuming incorrectly? Wouldn't there also be a torsional component as well?
