SteelPE
- Mar 9, 2006
- 2,759
I have a question about designing a combined footing to support a concentrically braced frame.
Generally, I size the footing to provide a FOS against overturning and sliding > 1.5. Once I know the general geometry I then check the footing bearing pressures against the allowable bearing pressure in the soils report. This requires me to calculate e (which is based off the service loads).
Once everything is acceptable I then need to size the footing for strength. In order to be in compliance with the ACI I need to get my moments in to an “LRFD” format. This is where I get a little confused. Am I supposed to recalculate an eu base on the ultimate load combinations. Or can I calculate the required forces (moments and shears) based off the service load combinations and then factor the loads using a “Psuedo” load factor?
I have run into instances where during the initial design the footing will work (e < L/2) but when I use the factored loads the footing no longer works (eu > L/2).
Sorry if this is a simple question but I just can’t find an example of a footing with large eccentricities.
