Try using a decent HeNe laser with a collimator. Lower quality diode lasers can yield oval spots and generally diverge alot over distance. You may also try to create a smaller aperture over the beam with a pin hole in a business card where it leaves the level. This will greatly attenuate the intensity of the beam though.
Good luck and I hope this helps.
Scott
In a hundred years, it isn't going to matter anyway.
