Hi guys. Any of you ever experienced foam in a suction scrubber? Client has a tank vapor recovery system, ~0 psig suction, 190 F suction temp, 20 psig discharge, constant-speed rotary vane compressor, 150 hp, capacity control is by discharge bypass recycle. Gas is (on dry basis) ~65% CO2, ~30% C1, ~7500 ppm H2s and other sulfur compounds including mercaptans, remainder is C2 and larger, is equilibrium water-saturated at process P & T, and has other good stuff in it like trace tiny solids (mostly iron sulfide) plus the typical dirty process plant detritus and bullcrap. The foam carries over out of the scrubber, gets into the compressor and you know what happens next. Bang.
Prevailing theory for root cause of foam formation is the recycle stream, which is lube-oil-laden is somehow reacting with one or more components in the process gas or its condensate to cause the foam. No basis in fact yet. I'm thinking the first thing to try is to reroute the bypass out of the suction system and see what happens.
Just looking for any ideas or "this one's a no-sh*tter" been-there-done-that-and-here's-how-we-fixed-it stories. Thanks guys. Pete
