Hello Experts,
Your valuable expert comments are required for following case,
Is balancing line used only for rotor balancing axially or same line used for seal balancing of Dry Gas Seals?
It is usually a single line for both. I have seen one compressor (1955 Clark) that had separate lines for thrust balance and seal chamber pressure control.
