What you will note is that I first ran the NX Sheet Metal 'Claenup' utility (this resulted in the creation of 'Body(2)'. I then used the 'Convert to Sheet Metal' function to get a model which could then be 'Flattened' using the normal NX Sheet Metal functionality.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA Siemens PLM: UG/NX Museum:
Three steps:
1) Blend the two sharp edges. Nothing can be bent 100% sharp.
2) In the Sheet metal Application, Use the Convert to sheet metal.
3) Sheet metal app.: Flat Pattern.
