Madhu454
- May 13, 2011
- 129
Hi All,
I am very new to GD&T and started learning from few months back. This is my first drawing for which I tried to apply GD&T.This is just a practice drawing where I am trying to tolerance two parts to achieve a clearance fit. (to be assembled manually, there should not be much play but easily removable.).
Please see the attached file. I have shown “Plate with rectangular tab” in pictorial view for better visualization.
I have used Profile of a surface to achieve the fit.
The minimum clearance is zero (Virtual size for both is 19.9)
The maximum clearance is 0.4 (Max hole size 20.1 - Min tab size 19.7), i.e., 0.2 each side.
I got following doubts while creating the drawings.
1) Whether my approach is right?
2) Is there any other way can I achieve the same fit?
3) I have used flatness and perpendicularity controls to qualify the datums. To what accuracy I need to control these surfaces? I mean how to decide the tolerances for these datum qualifications? Is there any guideline or best practice to calculate this?
4) To loacte the square tab and hole, the basic dimension 35 is given to one of the side face. Is that Okay? or Do I need to locate the tab to the mid line (center line). which is the best practice.
Thanks for your time.
Madhusudhan Veerappa
Mechanical Engineer
Mechanical Engineer
