It certainly was a tragic disaster that is all too common in crowded facilities with pyrotechnics that are notoriously unpredictable and administered. It seems it was more of a administrative failure to allow functions and not a structural or professional problem.
From my experiences, Brazil (actually Brasil) is very progressive in engineering and general design parameters. The last time I was there to give a structural and architectural design one day seminar for a college for an estimated 300 attendees, there ended up being 500 with the extra 200 in a separate room watching on TV. Most were registered professionals and a good percentage were students. This was not is a major city (coastal about 500,000 population).
Later, I went to Sao Paulo, the largest city in the Americas, and saw the projects under construction and talked to the engineers, I was in awe at the quality and controls of the way to work with and owner/developer on large projects of 10 to 20 buildings of 10 to 22 stories and make sure they were guaranteed to be built properly and economically. The materials were pre-approved and identified (color coded) when produced and the inspection avoided the archaic "clean-outs" for masonry and they used remote TV cameras to periodically inspect the construction. All mortar was to a higher spec (the highest required for the entire project) since they used a single automated plant for the site and higher strengths than needed were not detrimental. All grout was centrally batched since grout strength was not critical and full grouting was not allowed since the engineers wanted to control the behavior and rigidity of the 20 story 6" loadbearing structures.
After talking to the engineers that designed the projects, I made the err of asking what codes they used. They said "We use your current codes, but we use them better" since they were trained using the basics of masonry design from Southern California from the 1960's and 1970's and the threads remain.
After looking at my photos weeks later, I saw many things that I did not appreciate then. I found a shot with an elevation of the plans color coded for the strength of the units that was posted on the over-sized prints used there, since they are done to insure that everyone can understand even if they cannot read.
It was an engineering experience, but when is comes to rock concerts and visual displays everything is possible and money talks everywhere.
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
