Section J5.2 of the 2010 AISC Specification addresses filler plates in bolted connections. When a bolt that carries load passes through filler plates that are greater than 1/4" thick, the shear strength of the bolts shall be multiplied by factor 1-0.4(t-0.25) but not less than 0.85 which limits t to 5/8". How are bolts checked in the connection with filler plate greater than 5/8”?
iv
iv
