If straight bolts are going to be used into the holes of a part similar to the one from fig 7-27 (Y14.5-2009) and the thru holes are secondary datum feature ( as per the part function) how to specify in GDT language that the holes (as a pattern) are datum feature?
Lets say Surface C is primary (datum feature C) and the eight holes are, as a pattern, datum feature E, positioned within 0.5 at M at Surface C and also positined within 1 at M at Surface D, how to say the holes makes datum feature E
Ignore original datum A and B shown on the drawing for my question clarity.
We would like to use the holes as datum feature and allow more tolerance one one side (Surface D) versus the other (Surface C), but not sure how to say and show it correctly since the tolerance zone is conical.
