CobusvanJ
- Dec 6, 2008
- 45
Please help me with the following questions regarding field pressure testing (Vessels are ASME VIII Div. 1):
1. The supplier of a vessel to a client of ours managed to ship the vessel to site without final release inspection, and now the vessel requires major repairs (i.e. a 1200mm flange that is skew has to be cut off and rewelded). The vessel has not been commissioned. In this case of a major repair on site before commissioning, does a test pressure have to be repeated at shop test pressure value?
2. We have two vessels that were seperately shop pressure tested that will be welded together nozzle-to-nozzle on site. Somewhat like a column with a heat exchanger hanging off it. Does the combined assembly have to be pressure tested again?
