Femap V9.0 force vectors
AndyLake
FI
I’m using an NE Nastran and Femap 9.0. The problem is that I can’t possibly remove the constraint force vectors. Those vectors are still in place although “Deformed style” is setted to “None”. That’s not desirable when I want to present the element model without vectors. The only way to remove the vectors is to delete output set.
I'm not sure as to exactly what you mean but it might be that the freebody display is on. If so, try turning it off.
Good Luck
Thomas
That helps, thanks a lot!
