For an upcoming project, required to familiarize with FEMAP. Its a quite user friendly post & pre-processor compared to PATRAN. I was going through FEMAP demo videos and hit up on an interesting feature. The ability to display beam Shear Force & Bending Moment Diagrams in post-processing for CBAR/CBEAM elements. I believe the ability exists in MSC PATRAN as well but as far as I know, it is only possible with CBAR and not CBEAM elements.
Anyways, my first question is, how do I include more than one constraint set in Analysis Manager? I created a simple cantilever beam and then decided to add another fixed constraint set on the free end effectively making it a fixed-fixed beam. So there are two fixed constraints (lets name it Fixed 1 & Fixed 2). Moved the loading point to some where around middle of the beam's length. When I create a new Analysis, I see only one constraint along with loading set i.e. Fixed 1 with load. Using edit, I can change the constraint set to Fixed 2 or None but there is no option to add the other constraint set so that I can have both Fixed 1 & Fixed 2 with loading. I used multi-set to see if I can achieve the above, but it spit out two cases with each case containing just one constraint & loading.
I am sure I am missing something simple because I can't imagine an advanced software like FEMAP having the inability to do the above.
The second question involves post-processing. I am unable to get a complete i.e. all along the length of the beam, output of the Bending Moment. I am not sure if I am selecting the correct output option. I have tried both Beam End A Plane 1 Moment & Beam End B Plane 1 Moment output options, but get the same results.
Here is a tutorial based on an older FEMAP version (I think) where the output shows complete beam moment diagram.
Would appreciate some guidance on the above.
Thanks in advance,
-Burner
Thanks in advance,
-Burner
