brightinstinct
- Aug 8, 2002
- 6
Hi Everyone
I need to carryout a FEA using ANSYS on a designed PV to know the number of cycles that the vessel body and Locking ring can be subjected to under Fatigue.I am looking for some references for similar kind of analysis done.
VESSEL SPECIFIACTION
Design Pressure: 11,000 psi
Max Working Pressure: 10,000 psi
Volume: 7.5 Litres
Temperature: -20 to 150 Degrees Celsius
Internal dims (approx): 126mm bore x 600mm long
DESIGN CODE
PD5500 2003 Cat 1, Asme VIII Div 2 (For Fatigue)
I have never done any FEA for fatigue, so i needed some clue very urgently to start the work.Also please let me know where i can find code PD500.
could you please shed some light on this.
sanjay
Volume: 7.5 Litres
DESIGN CODE
sanjay
