fabricators of pressure vessels? 3
cmn8226
32
Anyone know any shop with ASME certification (with radiographic, LP, WPS/PQR, etc etc)that can fabricate pressure vessels? specifically Static mixers from carbon steel and stainless steel. Its gotta be in the Houston, TX area.
There should be no end of them down there- tried the yellow pages?
thanks christine,
when you say U stamp, it takes me to exactly what I need. perfect.
I will say good luck. Due to the fact that industry is booming, it's mighty hard to get shop floor time in most PV shops in Houston these days. If you have a lot of lead time, then probably no problem. Again, good luck!
