I am not sure what the technical term is, but I am curious if anyone has experience with bolting an eye-bolt through the web of a channel.
We are trying to find a tie off point for someone which needs to be rated for 5,000 lbs. We have since decided on a different option, but one of the ideas discussed was to drill through the web of a channel and install an eye-bolt for a tie off. I'm curious what the structural checks would be in this situation? Web bearing due to the bolt? Any local bending or crippling?
Is practice common?
Thank you!
Is practice common?
Thank you!
