Is there a setting that allows me to change the resolution (not sure if that is even the correct terminology) of an extruded solid? When you extrude a sketch, the solid extrusion is not as smooth as the actual sketch. An example of this is in the picture attached. The light blue line is the sketch, and you can see the solid not exactly how the sketch is drawn.
This isn't a big deal when you are dealing with large parts, but I find it annoying when I am working with very small parts and zoom in and it looks different than how it should be.
