catserveng
I have an AB SLC5/04 with a Prosoft MVI46-MCM installed, I am trying to get data from two Woodward EasyGen controllers. The EasyGen's use extended MODBUS addressing, haven't been able to find how to use extended MODBUS addressing with the SLC and the MVI module.
When I use Modscan32 I use an address of 50001 and can recieve the desired data. If I try a number larger than 32767 in the config file for the MVI module in the SLC I get an error.
Any ideas? I'm in a gas field in Texas and I am running out of ideas.
Thank you, Mike
Thank you, Mike
