thread561-272761
I'm using UGS NX 7.0 version, and I have 2D sketches that are created from intersection curves. the 2D sketches are airfoil sections for a Transonic fan that are taken from different surfaces along the span of the blade.
from this thread:
JohnRBaker created a program that Discretize the airfoil section into equally spaces points. I'm currently using that program to do analysis on the blade.
the problem is that I need more resolution in terms of the number of points per sketch. right now the program makes a 1000 point per sketch which is not sufficient for the type of work I'm doing.
I was wondering if anyone can help me in obtaining a program that creates a 100,000 points instead of the 1000 points per sketch
from this thread:
