To unit balance an exponent, nth-root, or derivative equation, the units of the result must depend only on the units of the arguments, not on the numeric value of the arguments. Explicit (constant) values must be used to calculate the powers of a quantity with units. This means you cannot assign the exponent, radical, or order of the derivative with a function argument, or a variable name defined in the worksheet.
