Explosions, or rather "impulsively loaded vessels" are very complex. There is a special working group in the ASME Code Committees that is currently working on rules for this topic.
If I recall correctly, this gets into strain-rate-sensitive deformation - if the strain rate is very high in "tough" materials, then the instantaneous pressure could be higher than the steady-state pressure that would cause a vessel to "fail".
I would check out the ASME PVP Conference papers to see what's been done in the last 5 years. There has been work done by LANL - they were designing pressure vessels to test high explosives.
