iyota
- Mar 1, 2009
- 7
Hello friends,
We're designing a building about 100ft x 330ft long, with 4 basement floors.
An expansion joint is provided from ground level to the roof.
However, I feel that we should NOT put an expansion joint in the basement box. This is because it is about 30ft underwater and in reclaimed sand. So it's practically under the sea. A flexible joint could be a big problem. Besides, basements are subject to less temperature change.
But I have doubts if this is ok (no exp joint in basement)
Any opinions? What do you think?
Thank you in advance!
