DaveAtkins
- Apr 15, 2002
- 2,895
Assume an expansion bolt connects something to a concrete foundation wall and is loaded in shear PARALLEL to the wall, with plenty of concrete in either direction parallel to the wall. Assume the expansion bolt is close to the edge of the wall in the PERPENDICULAR direction. Should the recommended shear reduction factor be used, even though the load does not act perpendicular to the wall?
I have always conservatively used the reduction factor in this situation, because I believe expansion bolts resist shear through "shear friction", and a tension cone failure must be avoided, even under shear load. I welcome any comments. DaveAtkins
