Excess pore water pressure
killswitchengage
Geotechnical
DZ
Hi i am just a bit confused about the significance of the h in the excess pore water pressure formula
h is the length of the drainage path.
that's what its supposed to be , but the exercises i am reading right now do not respect the true length of the drainage path
say its drained from 2 sides , then it should equal H/2 which does not ....
If the height of the sample is X and it can drain from the top and the bottom, then the length of the drainage path is X/2. The longest path a molecule of water would have to travel in order to drain is X/2. This would be for water in the middle of the sample. If it was above the middle, it would drain up. If it was below the middle, it would drain down. So h=X/2. If the sample was only drained on one side, then h=X.
that's what i had in mind , so i bet the exercise was false
thank you
