SpiderMann
New member
Greetings!
I need some help estimating the moments of Inertia (MOI) for an aircraft that has no published data. The information I do have is: Weight(34000 lbs), Length(62.1 ft), Wingspan(44.5 ft). The way I understand it, in theory, these are calculated by summing the product of the mass of each component with the square of its position radius about the axis. I have one method for estimating MOI's that uses only basic aircraft weight and dimensions combined with a set of coefficients of radii of gyration for several specific aircraft. We simply determine which aircraft is similar to the design we are concerned with, take the coefficients for each axis and the approriate dimension and calculate MOI's. The trouble is none of the radii are anywhere near the AC in question, and the coefficients are not published.
The formulas I have are:
Ix=(W/g)*(Rx*b/2)^2
Iy=(W/g)*(Ry*d/2)^2
Iz=(W/g)*(Rz*e/2)^2
where g=32.2 (gravity acceleration)
W=empty weight (lb)
b=span (feet)
d=length (feet)
e=(b+d)/2
and Rx, Ry and Rz are chosen from a table for the aircraft type (which the AC in question is not listed).
I guess my question is: How do I go about calculating MOI's when the datum is not complete?
Thanks for any assistance and forgive my ignorance if any of this is incorrect!
-Spider
Ix=(W/g)*(Rx*b/2)^2
Iy=(W/g)*(Ry*d/2)^2
Iz=(W/g)*(Rz*e/2)^2
W=empty weight (lb)
b=span (feet)
d=length (feet)
e=(b+d)/2
-Spider
