stryker1080
- Jul 21, 2011
- 7
I was wondering if people can provide some guidance as to various criteria for when one can expect first indications of cracking. Couple of specific questions i have
1) When doing an ASME Div 2 - Part 5 analysis, i understand that this method lets you determine the permissible number of cycles with an accepted factor of safety. Out of curiosity, what is the basis of this method? For B31.3 piping tests by Markl, they did the tests until water leaked (through wall crack) and they applied an arbitrary FOS on stress and cycles (~2 on stress and ~20 on cycle).
Is the same basis done for Div 2 - Part 5? In that case, is it possible to start seeing cracks even if you are only at 5, 10, or 20% of your permissible cycles? Any literature that people can recommend on this subject?
2) Can someone recommend some literature or codes which would reference an approximate estimate for when you would expect to see cracks. I'm looking something along the lines of:
- B31.8 has some guidance as to allowable strain (4% and 6%) used for dent evaluation. Some literature i read suggests that first cracking can be seen around ~ 12% plastic strain. Would performing a linear elastic-perfectly plastic or a plastic analysis and looking at the plastic strain be a good indicator?
- Some reference i read have a simple formula which includes a ratio of principle stresses to von mises (gives you a ratio of the triaxality) and multiples that by the uni-axial failure strain to give you a "new" failure strain.
Just curious what people are using as a criteria.
I am asking more out of curiosity. We came across a situation where we had a local bake out on a vessel and it did not have uniform gradient across a discontinuity. We inspected the vessel post bake out and found no cracks. Contractor says they do this all the time... For interest sake, i did an FEA and ran a thermal analysis followed by stress analysis and found fairly high stresses at the discontinuitiy. Wanted to get a "data point" or gauge what stress level or strain would be a good level for when to definatley inspect or what areas to focus on...
