KootK
- Oct 16, 2001
- 18,617
I've got one or two questions, depending on the answer to the first I guess. Here we go:
1) For slab design, the code allows you to consider one story (floor) at a time. You include the columns above and below the floor under consideration and consider your columns to be fixed at their far ends.
This is just peachy for the slab. However, many in my office assume that that model applies to the design of the columns at that level as well. i.e. you could take the moments from this siimplified analysis, throw in your axial load considering all floors above, and design the columns. Is this appropriate? Does the code explicitly allow this method somewhere in ACI? This doesn't seem right to me, especially where pattern loads are involved.
I might be willing to buy into this method in situations where double curvature can be guaranteed (regular column layout / no pattern loading). In this case I think that the carry over moments would tend to oppose the unbalanced moment at any particular joint.
2) Assuming that the method in question #1 is NOT suitable for determining column design loads, how the heck do you do it? It seems to me that, in a monolithic RC building, the biaxial moments at EVERY floor in the building will contribute to the column moments (and slab moments for that matter) at any particular level via carryover effects.
I admit that, as you move further from the floor being considred, the impact will die off quickly. So... how many floors should one consider? Again this strikes me especially important when patters loads are being considered or when column layout changes from floor to floor.
Thanks guys.
P.S. I'm not interested in doing an FEM model of the entire buidling.
Thanks guys.
