epoxy e-coat thread masking 1
davej
Industrial
I am looking for a suitable material to use for masking the threads of a nut that is welded to a part that is to be epoxy e-coated. We do not want to use a silicon plug to mask the threads, but wish to have a chemical paint release agent applied by the nut manufacturer. The service doing my e-coating is concerned about contaminating their cleaning bath solutions with anything we might use. Is a suitable release agent available?
Will this also work on threads which are powder coated?
franklineng,
Are you asking if fluorocarbon thread masking will prevent powder coat adhesion to threaded fasteners? Yes, it can help prevent this.
Specificy we have a small part which we manufacture which as a tapped hole. Time and time again, we are receiving this part back from powder coating with paint on the thread. One problem using a protective coating, is the part is hung through the hole as it goes through powedercoating.
franklineng,
I think your problems are straightforward. You should contact either of the companies I listed above. They can help you specify a thread masking compound that can minimize the problems you are having.
Use a conductive mask on your rack which will allow you to rack the part while masking the threaded hole in one operation. They're also re-usable and will take 500F temps.
