The NIST webbook allows you to select the units you prefer among: mol/L, mol/m3, g/mL, kg/m3, lb-mole/ft3, lbm/ft3, and so is also with specific volumes (the reverse units). The table also says at the end of each row whether the properties belong to a liquid or a vapour. While switching from saturated liquid to saturated vapour on two consecutive lines at different pressures you get the properties of both liquid and vapor. By combining the proportional individual enthalpies you get the enthalpy of the mix.
