I have a question about where the top of an embed plate is typically placed with reference to the top of a cmu wall. Please see the attached sketch for reference. Option 1 shows the plate sitting on the top of the wall (bottom of the plate is at the same elevation as the top of the wall). Option 2 shows the top of the embed plate level with the top of the wall. And option 3 also shows the top of the embed plate level with the top of the wall but with the cmu flange notched (this would maybe be done if the plate is too wide to fit between the cmu flanges).
I have seen it detailed all three ways but was wandering what is typically constructed. I would typically think they would construct it how it is detailed, but my experience with masons is that they kind of do whatever they want.
I am curious because if I call out a deck bearing elevation on plan as some elevation that matches cmu coursing, and option 1 is what is typically done, the very top course of cmu would have to be cut to a depth equal to the thickness of the embed plate.
Thanks!
Thanks!
