embankment construction
Robbo100
AU
I have a contractor who insists that he can construct a small dam wall with a scraper. The specification calls for screening out material larger than 75mm - for obvious reasons.
The contractor insists that he can use a scraper to run out rocks bigger than 75mm diameter.
How feasible is this?
I'd be rather surprised if he could. How would he do that?
What do you mean by a "dam wall"? I don't think I recognize that term.
dgillette,
In some countries, they call the dam the "dam wall", and they call the impoundment the "dam". I don't know where Robbo is located, but in Australia ponds, reservoirs, etc. are often called dams.
If he also has a crew of laborers walking behind the scraper, picking rocks than he's good to go.
If you were talking more like 150mm, then more feasible. 75mm is a bit small, and he would have to drop a very thin lift.
I am in Australia. Let's call it a sludge lagoon to be more precise.
But this is about what we figured. Thanks guys
