Hello Everyone,
I am hoping someone can clarify some basic issues regarding motor operation for me.
I have a conveyor that has installed on it 1 HP/1750 RPM 3 phase motor with a 40:1 Gear Reducer. I also have installed an inverter to vary the conveyor speed between 5 – 20 RPM. Is it correct to say - that the gear reducer reduces the conveyor speed to 43 RPM and to achieve any speed lower than 43 RPM the motor speed must be reduced with the inverter? Also, does the output HP from the motor vary with speed? If so, how can I determine the output HP at my various conveyor speeds?
I would like to calculate the output HP because during the conveyor operation the motor keeps stalling. I am trying to determine if the system is undersized in torque, HP or both so I can correctly size a new drive system to run the conveyor.
Any input would be much appreciated.
