Eclipse 100 error
Bekzat
Student
May 1, 2025
Hello everyone
I'm currently a student working on my diploma (graduation) project, and as part of the final section I would like to present a production forecast using Eclipse 100.
However, I’m facing some errors during the simulation, and unfortunately, I haven't been able to resolve them on my own. I'm kindly reaching out to see if anyone here might be able to help or guide me in the right direction.
Any support or suggestions would be truly appreciated!
Thank you in advance 🙏
@-- ERROR AT TIME 0.0 DAYS (30-MAY-2025):
@ UNRECOGNISED KEYWORD PERMX 5. IN GRID DATA
18 READING PERMY 5.
@ UNRECOGNISED KEYWORD PERMY 5. IN GRID DATA
19 READING PERMZ 5.
@ UNRECOGNISED KEYWORD PERMZ 5. IN GRID DATA
@--WARNING AT TIME 0.0 DAYS (30-MAY-2025):
@ SPURIOUS DATA BEFORE ENDBOX KEYWORD
20 READING ENDBOX
21 READING PORO
22 READING INIT
23 READING PROPS
@--MESSAGE AT TIME 0.0 DAYS (30-MAY-2025):
@ UNSPECIFIED TOPS VALUES OBTAINED BY ADDING DZ
@ TO TOPS VALUE FOR LAYER ABOVE
@ NEITHER OLDTRAN,OLDTRANR NOR NEWTRAN SPECIFIED
@ BLOCK CENTRE TRANSMISSIBILITIES TO BE CALCULATED
@ USING OLDTRAN
@ INSUFFICIENT DATA TO COMPUTE PORE VOLUMES
@ PORE VOLUMES WILL BE SET TO ZERO
@ INSUFFICIENT DATA TO COMPUTE CELL CENTRE DEPTHS
@ INSUFFICIENT DATA TO COMPUTE X TRANSMISSIBILITIES
@ INSUFFICIENT DATA TO COMPUTE Y TRANSMISSIBILITIES
@ INSUFFICIENT DATA TO COMPUTE Z TRANSMISSIBILITIES
@--COMMENT AT TIME 0.0 DAYS (30-MAY-2025):
@ NO NON-NEIGHBOUR CONNECTIONS FOUND
@ NUMBER OF ACTIVE CELLS IS 0
@ THERE ARE NO ACTIVE CELLS IN THE RESERVOIR
I assume you don't have a user manual, nor anyone who has used this s/ware ?
have you run a tutorial problem ? It is obvious that you have really confused it !
A google search "eclipse 100 manual" returned a bunch of hits which looked applicable ??
YT is often a good source ...
Thank you for your response! I’m a student and I’m currently using the university’s version. I wrote the code myself, but since I don’t have much experience yet, I’ve encountered some issues. Could you please help me with them?
sorry, no ... as I don't know anything about what you are doing.
Is "eclipse 100" a language, like Python ?
You "wrote the code" ... is this "code" a specific problem solving or a more generalised code ??
Is there no one there who can help, a thesis supervisor ??
What support do you have ? Maybe someone said "here is something, make it work" ?
Look for Schlumberger Eclipse 100. It's a permeability modeling software for petroleum and water subsurface movement.
Looking at error messages doesn't tell what is wrong with the file. It tells where in the file to look for what caused a cascade of problems. It could be an extra tab character or a comma instead of a semicolon.
There should be a course in software debugging given in the freshman year as there are plenty of ways for user input to cause software to misbehave, sometimes "running" but giving garbage answers.
