Eclipse 100 error
Bekzat
Student
May 1, 2025
Hello everyone
I'm currently a student working on my diploma (graduation) project, and as part of the final section I would like to present a production forecast using Eclipse 100.
However, I’m facing some errors during the simulation, and unfortunately, I haven't been able to resolve them on my own. I'm kindly reaching out to see if anyone here might be able to help or guide me in the right direction.
Any support or suggestions would be truly appreciated!
Thank you in advance 🙏
@-- ERROR AT TIME 0.0 DAYS (30-MAY-2025):
@ UNRECOGNISED KEYWORD PERMX 5. IN GRID DATA
18 READING PERMY 5.
@ UNRECOGNISED KEYWORD PERMY 5. IN GRID DATA
19 READING PERMZ 5.
@ UNRECOGNISED KEYWORD PERMZ 5. IN GRID DATA
@--WARNING AT TIME 0.0 DAYS (30-MAY-2025):
@ SPURIOUS DATA BEFORE ENDBOX KEYWORD
20 READING ENDBOX
21 READING PORO
22 READING INIT
23 READING PROPS
@--MESSAGE AT TIME 0.0 DAYS (30-MAY-2025):
@ UNSPECIFIED TOPS VALUES OBTAINED BY ADDING DZ
@ TO TOPS VALUE FOR LAYER ABOVE
@ NEITHER OLDTRAN,OLDTRANR NOR NEWTRAN SPECIFIED
@ BLOCK CENTRE TRANSMISSIBILITIES TO BE CALCULATED
@ USING OLDTRAN
@ INSUFFICIENT DATA TO COMPUTE PORE VOLUMES
@ PORE VOLUMES WILL BE SET TO ZERO
@ INSUFFICIENT DATA TO COMPUTE CELL CENTRE DEPTHS
@ INSUFFICIENT DATA TO COMPUTE X TRANSMISSIBILITIES
@ INSUFFICIENT DATA TO COMPUTE Y TRANSMISSIBILITIES
@ INSUFFICIENT DATA TO COMPUTE Z TRANSMISSIBILITIES
@--COMMENT AT TIME 0.0 DAYS (30-MAY-2025):
@ NO NON-NEIGHBOUR CONNECTIONS FOUND
@ NUMBER OF ACTIVE CELLS IS 0
@ THERE ARE NO ACTIVE CELLS IN THE RESERVOIR
I assume you don't have a user manual, nor anyone who has used this s/ware ?
have you run a tutorial problem ? It is obvious that you have really confused it !
A google search "eclipse 100 manual" returned a bunch of hits which looked applicable ??
YT is often a good source ...
Thank you for your response! I’m a student and I’m currently using the university’s version. I wrote the code myself, but since I don’t have much experience yet, I’ve encountered some issues. Could you please help me with them?
sorry, no ... as I don't know anything about what you are doing.
Is "eclipse 100" a language, like Python ?
You "wrote the code" ... is this "code" a specific problem solving or a more generalised code ??
Is there no one there who can help, a thesis supervisor ??
What support do you have ? Maybe someone said "here is something, make it work" ?
Look for Schlumberger Eclipse 100. It's a permeability modeling software for petroleum and water subsurface movement.
Looking at error messages doesn't tell what is wrong with the file. It tells where in the file to look for what caused a cascade of problems. It could be an extra tab character or a comma instead of a semicolon.
There should be a course in software debugging given in the freshman year as there are plenty of ways for user input to cause software to misbehave, sometimes "running" but giving garbage answers.
Given that some of the inputs don't generate errors, it's likely to be typos or formatting errors in the input.
I used to use a simulation program whose input was still based on punch card formatting, so a slip in column position would throw a catastrophic error, often with no obvious warnings from the program. Likewise, if the inputs weren't correctly formatted, it would throw errors.
Actually, I would still be using that program, even though they upgraded to a more free form input, because their GUI was so obtuse.
I liked the C compilers that would throw an "Unmatched Brace" error with the line number of the last line of the program because I missed one a few hundred lines earlier. I know it could not guess where the problem was, but the fake-out on the line number was just putting salt on the wound.
arrgghh, don't get me started on rants about programming. I recently encountered an app where I needed to input my birthdate, but rather than the usual mm/dd/yyyy input, the a$$hole programmer put in a calendar app because they were too lazy to figure out how to parse a date string, so I had to click the back a month button more than 700 times, because I'm THAT old. There should be a place in hell for lazy programmers. What was doubly annoying is that elsewhere in the app, someone else already coded a mm/dd/yyyy input parser.
On the Windows day/date/time calendar, clicking on the month switches to showing just the year and all the months. Clicking then on the year shows a panel of years. Perhaps the one you had does the same??
3 clicks:
I have looked at time software underpinnings and most everyone involved with it says two things. One is, that way lies madness and the other is. use someone else's library. The mess that calendars and time has become what with everyone f'ing with it ... Like, is it daylight savings time? Does it include the segments where that was extended or shortened? Is it a date and time from outside the current time zone? Does it include when the number of seconds in a year is tweaked?
Wasn't Windows. It was a parking app on Android, and no, there was no choice to change the year. Like I said, lazy programmer who probably just grabbed a cheap, available, calendar module and didn't even bother to figure out what actually needed to be done, IRL.
There's a cascading hierarchy of clocks and time representations. At the top is a conglomerate of master time keepers, like the USNO timebase, which spits out UTC time, which is corrected for leap seconds every so often. Then, there's a truckload of secondary and tertiary timebases that synchronize to official UTC time. Windows synchronizes directly to one of the distributed UTC reference timebases. Everything beyond that, like time zones, etc., are all conventions, e.g., whatever DST might be or say, UTC is still correct; since you choose, or your computer chooses, what time zone you're in, the convention takes care of everything else, including DST. So, if you were to log your computer's time output by the second, you should see a sudden jump in the time when leap seconds are added to UTC.
I don't mean - what time is it now. I mean, how many seconds have elapsed between Jan 1, 1885, 12:00AM and the time it is now, if the first time is in Sumatra and the current time is in Oslo. It's handling all of the legal time definition changes in the end points that's the reason time software is a problem.
Nevetheless, a birthdate is still a birthdate, and lazy is still lazy.
In looking more about Android calendar GUI's I came across an example that mentioned that Android does not include a fundamental calendar interface.
Android does have functions to handle time calculations. It's always weird when an OS doesn't include a common function like choosing dates when it does include it's own Calendar manager for setting reminders and the like.
Here's a parallel stupidity - in Excel they have a setting for the "origin" of time. This is mainly because the Microsoft OS team and the Apple OS team chose different origins and, when Microsoft created Excel, they just defaulted to the OS origin.
What makes this stupid, aside from trouble for the number of people I worked with who got massively f'd over when sharing spreadsheets between the two, is that Excel doesn't have a similar switch for working in Degrees vs. Radians. I cannot tell the excess effort the requirement in using the DEG or the RAD function because actual spreadsheet users aren't mathematicians and rarely use radians. But I am sure MS would find a way to f' the up as well. Sigh.
software developers deserve their own ring of hell
