Hello everyone
I'm currently a student working on my diploma (graduation) project, and as part of the final section I would like to present a production forecast using Eclipse 100.
However, I’m facing some errors during the simulation, and unfortunately, I haven't been able to resolve them on my own. I'm kindly reaching out to see if anyone here might be able to help or guide me in the right direction.
Any support or suggestions would be truly appreciated!
Thank you in advance
@-- ERROR AT TIME 0.0 DAYS (30-MAY-2025):
@ UNRECOGNISED KEYWORD PERMX 5. IN GRID DATA
18 READING PERMY 5.
@ UNRECOGNISED KEYWORD PERMY 5. IN GRID DATA
19 READING PERMZ 5.
@ UNRECOGNISED KEYWORD PERMZ 5. IN GRID DATA
@--WARNING AT TIME 0.0 DAYS (30-MAY-2025):
@ SPURIOUS DATA BEFORE ENDBOX KEYWORD
20 READING ENDBOX
21 READING PORO
22 READING INIT
23 READING PROPS
@--MESSAGE AT TIME 0.0 DAYS (30-MAY-2025):
@ UNSPECIFIED TOPS VALUES OBTAINED BY ADDING DZ
@ TO TOPS VALUE FOR LAYER ABOVE
@ NEITHER OLDTRAN,OLDTRANR NOR NEWTRAN SPECIFIED
@ BLOCK CENTRE TRANSMISSIBILITIES TO BE CALCULATED
@ USING OLDTRAN
@ INSUFFICIENT DATA TO COMPUTE PORE VOLUMES
@ PORE VOLUMES WILL BE SET TO ZERO
@ INSUFFICIENT DATA TO COMPUTE CELL CENTRE DEPTHS
@ INSUFFICIENT DATA TO COMPUTE X TRANSMISSIBILITIES
@ INSUFFICIENT DATA TO COMPUTE Y TRANSMISSIBILITIES
@ INSUFFICIENT DATA TO COMPUTE Z TRANSMISSIBILITIES
@--COMMENT AT TIME 0.0 DAYS (30-MAY-2025):
@ NO NON-NEIGHBOUR CONNECTIONS FOUND
@ NUMBER OF ACTIVE CELLS IS 0
@ THERE ARE NO ACTIVE CELLS IN THE RESERVOIR
18 READING PERMY 5.
19 READING PERMZ 5.
20 READING ENDBOX
21 READING PORO
22 READING INIT
23 READING PROPS
@ USING OLDTRAN
