Hi I have another question in regards to the precast wall to slab connection. Other than the previous one, this is for load bearing wall to slab. (I have had a look on the manual that I was recommended by still want to know your thoughts).
I have these 200mmx800mm panels with 4m spacing that attached to the slab and I wanna make them load bearing. I have put the design strip in light yellow and have no problem if the walls can be placed under the slab. But Now because the wall have to be placed outside of the slab and with the eccentricity by caused by the connection I am wondering if it is still doable? (Dowel bars are used to connect wall to slab)
I have uploaded the layout plan as shown below. Thanks in advance.
