revvedmoto
Well, this is a multi-faceted question that may change the direction of my dyno cell build. I've been googling different questions I’ve come up with while planning my dyno cell build. Between construction methods, soundproofing, and ventilation systems there seems to be very limited info out there. This forum and a few others had a few promising threads so I figured I would ask my questions here.
To Start I bought a used dynojet chassis motorcycle dyno earlier this year but after a dozen or so uses I started getting some noise complaints. I currently have the dyno in a metal shipping container where the whole side of the container opens to the world. I pretty much have been running this thing outside and it reverbs pretty good on the metal container. I'm still on the fence if the dyno will be left in the container and try to kill the reverb and exhaust note or if I'll be moving it into a room in my shop. All the bikes I tune will have an aftermarket exhaust pipe that arent very quiet which leads me to my first question.
During my exhaust quieting/extracting research, I came across two setups. Most seem to have a hose and funnel setup sitting a few inches from the exhaust but would make little to no difference in the sound department. This is also the method that dynojet recommends. The other method I've seen they slip the hose over and attach it to the exhaust, extracting the exhaust and sound. All these setups seem to be engine dynos.
I like this idea, but I have two concerns one being damaging someone’s exhaust by rubbing the finish. The second, assuming I’m powering this hose with an inline fan and then out a silencer, could the vacuum created potentially affect how the bike is tuned?
My thoughts were to wrap the exhaust in something soft and slip an oversized hose over the exhaust in the hopes of alleviating some of the pressure and hopefully collecting the majority of the sound.
I'm curious what you guys think, am I overthinking this, Is there a better method to extract the exhaust without affecting performance?
