Drawing bent rails in SW2003
Adrian2
303
Dear Folks;
I am modelling a diamond crossing for a railroad application. These consist of many bent rails and straight rails with holes drilled through the web to join them together.
My problem lies in the best way to model the bent rails. Presently I profile the the rail cross section and sweep it along the bent path. The path is basically a "C" shape made of 3 straight lines joined one after the other. Its important for one of the drilled holes to be located right in the center of the "C" shape. How do I accurately locate this center ?
I can locate the hole referencing an arbitrary point such as the line formed by the inside bend in the rail. But I would prefer to use the centerpoint of the straight line of the sweep path used in the center of the "C"
Does anyone have any suggestions ?
Best Regards
Adrian D
If you used a path to make the extrusion, why can't you just show your old sketch and convert the entity? that way it will follow the same exact path....or you could add both circles at the same time of the extrusion and save yourself a step. (2 concentric circles)
Scott Baugh, CSWP [worm]
3DVision Technologies
faq731-376
When in doubt, always check the help
Try using some reference geometry (centerlines and points) to mark the center of the segment in the sketch for later use. You can either constrain a centerline with a symmetry constraint between the endpoints of the guide and the centerline, or constrain a point to a curve using a midpoint constraint.
[bat]There's no double-lock defense; there's no chain on my door.
And I'm available for consultation,
but remember your way in is also my way out
[bat]
