JoelTXCive
I have a question regarding drains in retaining walls that have water on one side.
Attached is a preliminary drawing for a channel lining my firm is designing.
[ul]
[li]The sides will be designed as cantilevered retaining walls.[/li]
[li]A geotech engineer has performed a global stability analysis and said the proposed configuration will work.[/li]
[li]I'm hopeful that I can make the walls work with our large surcharge. I'm crunching numbers on this now.[/li]
[/ul]
The proposed channel is connecting two man made detention ponds. A normal Water Surface Elevation of 49.89' is expected. The elevation will increase up to a high of 51.82 in a 100yr storm event.
My question is:
1) Should we put drains in this wall? I believe our worst case loading scenario is going to be a rapid draw down situation with the channel empty and fully saturated hydrostatic pressure on the dirt side of the wall. Since we are going to be designing for a fully saturated scenario, then why does it matter if it drains?
2) If we do put drains in the wall, then at what elevation? At the base? 6" inches up? 1ft up the wall? Higher?
Thank you.
[ul]
[/ul]
My question is:
Thank you.
