Draft Adds mass of a Cored hole? 1
SDETERS
Agricultural
May 1, 2008
1,306
On a print if you specify a cored hole at the bigger side, then specify a 2 deg. draft adds mass, is the draft specified the included angle of the core, or is it per side? I believe it is per side (which would be a 4 deg Included angle) but can not find this in a standard any place. I also believe we need to define this better on the print.
We have a 1989 version Does it show this better in a new version?
Thanks for the feedback and help.
Fig. B-1 Sample Molded Part Drawing
From Y14.8-2009 shows 2 degrees included angle on a drafted hole
Time to update our standard. Thanks for the help.
SDETERS,
The time comes that you need a section view that shows explicitly and exactly what you want.
JHG
