Hello fellow engineers,
I am having some trouble trying to analyze the double angle bolted welded connection with both axial and shear force acting on it. Please see attached file for connection description. I was not able to find much information in the AISC manual, so hoping that you guys could help me out.
I am using a double angle connection bolted to the beam web and welded to the embed plate. The connection sees both axial and shear force on it. I can calculate the resultant force and check the capacity for the bolt for shear, but however, I am not sure how to check the weld strength. The weld experiences an eccentric loading and the angle will experience prying effect. Angle thickness will be designed to account for the prying effect.
Can anyone refer me or guide me on how to design/check the weld capacity for this connection. Since the axial load is high, it will see more tension than shear. Generally, Shear plate is preferred for this connection, but my axial load being high, shear tabs does not work.
Any help will be greatly appreciated. Thank you all.
