Hi
I hope you guys can help.
I have two parts that should be bolted together with four M6 bolts. The tolerances of the bottom part are quite big and the holes for this part are fixed to Ø6. The tolerances of both parts are fixed due to manufacturing and lowering of costs.
I need to determine the size of the holes of the top part in order for them to fit together. I have attached a photo showing the tolerances of both parts.
I am in doubt how to calculate the size of the holes. For instance for the left side, is this the correct way?
Diameter = Deltadim + Toldist + Dshaft= (211.5-210)+3.5 + 6 = 1.5 + 3.5 + 6 = Ø11
Thank you in advance
